Einleitung
Are you tired of pant legs that are too long and get caught under your shoes, causing you to trip or stumble? What if I told you all you needed was some double-sided fabric tape, iron or press, and a ruler to hem up those pants?
Was du brauchst
First, you want to try on the pants that need hemming.
Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
Creating a fold or crease will help keep your pant length the same on all sides.
Place the double-sided fabric tape on the edge of the pant legs.
I used a total of 4 - 1/2"x3" strips for each pant leg.
Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
You don't need a sewing machine to hem a pair of overly long pants.
