Zum Hauptinhalt wechseln
How To Install BMW E46 3 Series Switchback LED Halo Rings
Was du brauchst
  1. How To Install BMW E46 3 Series Switchback LED Halo Rings, Prepare to open the headlamp.: Schritt 1, Bild 1 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Prepare to open the headlamp.: Schritt 1, Bild 2 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Prepare to open the headlamp.: Schritt 1, Bild 3 von 3
    • Take a long screwdriver and insert it into the hole to remove the turn signal lamp.
    • Remove under headlamp plastic trim and the above headlamp rubber trim.
  2. How To Install BMW E46 3 Series Switchback LED Halo Rings, Open up the headlamps.: Schritt 2, Bild 1 von 2 How To Install BMW E46 3 Series Switchback LED Halo Rings, Open up the headlamps.: Schritt 2, Bild 2 von 2
    • Remove couple clips holding the headlamp lens and carefully remove the lens.
    • Remove the inside headlamp trim.
  3. How To Install BMW E46 3 Series Switchback LED Halo Rings, Install the LED halo rings.: Schritt 3, Bild 1 von 2 How To Install BMW E46 3 Series Switchback LED Halo Rings, Install the LED halo rings.: Schritt 3, Bild 2 von 2
    • Clip on the switchback LED angel eye rings. Grab the two black wires through the low beam bulb back openings.
    • Put back the black trim. If you install it properly, you will see that the LED halo rings align with the inside trim. You don't have to worry about the rings protruding out because the rings will be pushed back to their appropriate location when you install the lens back.
    • Afterwards, please work on the driver side since later you need to connect the wires together.
  4. How To Install BMW E46 3 Series Switchback LED Halo Rings, Install the module box.: Schritt 4, Bild 1 von 1
    • Plug the two wires to the module box. On the other end of the module box.
    • Yellow: Turn Signal; Red: White; Black: Ground.
    • Special note: You need to extend these wires for the installation.
  5. How To Install BMW E46 3 Series Switchback LED Halo Rings, Connect the wires.: Schritt 5, Bild 1 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Connect the wires.: Schritt 5, Bild 2 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Connect the wires.: Schritt 5, Bild 3 von 3
    • Tap the black wire to the bolt circled in red.
    • On the passenger side, merge the red wire on both driver and passenger side as indicated in the insert. You will need to extend the wires on both sides. Tap the merged red wire to ACC 12V+. There are a few ACC locations; in this case, we chose the blue striped wire.
    • On each side, extend the yellow wire from the module box to the left and right side markers. Tap it to the blue/yellow striped wire.
  6. How To Install BMW E46 3 Series Switchback LED Halo Rings, Put everything back.: Schritt 6, Bild 1 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Put everything back.: Schritt 6, Bild 2 von 3 How To Install BMW E46 3 Series Switchback LED Halo Rings, Put everything back.: Schritt 6, Bild 3 von 3
    • Test everything to make sure the BMW switchback LED halo rings work. Put everything back.
Abschluss
This mod will give your BMW a new look with xenon white LED halo rings with additional safety feature with amber signal function.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Wu
3.357 Reputation
23 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 109
Insgesamt: 25,157
