Zum Hauptinhalt wechseln
How To Patch a Hole in Umbrella Fabric
Was du brauchst
  1. How To Patch a Hole in Umbrella Fabric, Fabric: Schritt 1, Bild 1 von 1
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: Schritt 2, Bild 1 von 1
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: Schritt 3, Bild 1 von 1
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: Schritt 4, Bild 1 von 1
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: Schritt 5, Bild 1 von 1
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: Schritt 6, Bild 1 von 1
    • Apply your patch squarely over the torn fabric.
Abschluss
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 73
Letzte 30 Tage: 299
Insgesamt: 16,880
