Einleitung
Maintaining your electric lawn mower ensures safe and efficient operation every time you cut the grass. Regular cleaning and blade care prevent performance issues, reduce strain on the motor, and keep your lawn looking great. Always follow your manufacturer’s instructions and warranty conditions before servicing any part.
Was du brauchst
Schritt 2 Put on protective equipment
Use gloves to protect your hands during cleaning, blade removal, and sharpening tasks.
Schritt 3 Clean the grass collector
Wash the collector with a hose or suitable cleaning tool and let it dry thoroughly.
The main part of the mower should be kept clean and dry.
Schritt 4 Remove the rotating blade
Use a wrench on the central bolt to loosen and remove the rotating blade carefully.
Schritt 5 Clear debris from the underside
Vacuum or brush away grass buildup under the deck to keep the discharge path free.
Schritt 6 Tighten the handle fasteners
Secure loose handle bolts by tightening them to reduce the risk of damage during use.
Schritt 7 Inspect the motor compartment
Remove or open the cover to check for debris and use a vacuum if needed.
Schritt 8 Sharpen the blade
Use a grinder or sharpening tool and cool the blade with water periodically to prevent overheating.
Schritt 9 Reinstall the blade and secure the cable
Position the blade per the original orientation and tighten the bolt firmly.
In this case there is a self-tightening clutch at the back, which means that when the mower starts to run, the blade will tighten itself as much as it can.
Performing regular upkeep of your electric lawn mower helps avoid clogs, preserves engine performance, and extends the life of the machine. Contact an authorized professional if you encounter issues, and always consult your manufacturer’s guidelines to protect your warranty. Consistent cleaning and proper blade care will keep your equipment safe and reliable.
