Zum Hauptinhalt wechseln
How To Repair A Cat Torn Polyester Couch
Was du brauchst
    1. How To Repair A Cat Torn Polyester Couch, How To Repair A Cat Torn Polyester Couch: Schritt 1, Bild 1 von 2 How To Repair A Cat Torn Polyester Couch, How To Repair A Cat Torn Polyester Couch: Schritt 1, Bild 2 von 2
      • Use a pair of scissors or an x-acto knife to remove any large strands of thread.
      Frag FixBot
      Kommentar hinzufügen
    2. How To Repair A Cat Torn Polyester Couch: Schritt 2, Bild 1 von 1
      • Use a small razor to clean up any remaining small strands on the couch.
      • This will help make the damage itself more visible, letting you know where sewing will be most necessary.
      Frag FixBot
    3. How To Repair A Cat Torn Polyester Couch: Schritt 3, Bild 1 von 1
      • Insert the polyester, or nylon bonded, thread through your heavy-duty upholstery needle.
      Frag FixBot
    4. How To Repair A Cat Torn Polyester Couch: Schritt 4, Bild 1 von 1
      • To knot your thread, first loop the thread around your index finger at least three times.
      • Pinch the thread with your thumb, and slowly roll the thread off of your fingertip with your thumb
      Frag FixBot
    5. How To Repair A Cat Torn Polyester Couch: Schritt 5, Bild 1 von 1
      • Pinch and pull the thread you just rolled towards you to finalize the knot.
      • You may cut off any excess thread if necessary.
      Frag FixBot
    6. How To Repair A Cat Torn Polyester Couch: Schritt 6, Bild 1 von 1
      • Piercing the needle into a corner of the hole where the stitching is still strong enough to hold the thread.
      • You will want to pierce from below the surface to the front, so you are pulling the thread towards the front.
      • Pull the thread all the way through until it hits the knot.
      Frag FixBot
    7. How To Repair A Cat Torn Polyester Couch: Schritt 7, Bild 1 von 1
      • Pierce another hole directly vertically straight across from your first hole.
      • You want to pierce front to back, so you pull the thread through the back of the cloth.
      • Pull the thread all the way through.
      Frag FixBot
    8. How To Repair A Cat Torn Polyester Couch: Schritt 8, Bild 1 von 1
      • Pierce the next hole vertically across again, but one thread-width to the side of the previous holes. Pierce back-to-front.
      • The next hole will go vertically straight across and front-to-back.
      • This will make a parallel stitch to your first stitch.
      • Repeat making parallel lines of stitches until the area of the hole is covered by vertical stitches.
      Frag FixBot
    9. How To Repair A Cat Torn Polyester Couch: Schritt 9, Bild 1 von 1
      • Wherever your last stitch ended, pierce a hole at the closest corner of the entire stitching. Pull the thread all the way through.
      • This will hold the vertical stitches as we switch directions.
      • Push the needle over and under the vertical threads, alternating each thread.
      Frag FixBot
    10. How To Repair A Cat Torn Polyester Couch: Schritt 10, Bild 1 von 1
      • Pierce the needle into the cloth front-to-back, then make another hole offset vertically back-to-front.
      • This is the end of the first weave stitch and the beginning of the next.
      • Pull the thread through and weave the needle across the vertical stitches again.
      • End the stitch with a hole that pierces beside it and begins the next stitch.
      Frag FixBot
    11. How To Repair A Cat Torn Polyester Couch: Schritt 11, Bild 1 von 1
      • When the entire area is woven over, tie a simple knot at the end and cut off the excess thread.
      • The knot can be hidden by being pushed under the weave.
      • Any other loose threads or fuzz can be cut off using the scissors or razor.
      Frag FixBot
Abschluss
You've now mended your couch!
Gerrard Reyes
193 Reputation
1 Anleitung geschrieben
UC Davis, Team 3-3, Whithaus Spring 2026 Mitglied von UC Davis, Team 3-3, Whithaus Spring 2026
UCD-WHITHAUS-S26S3G3
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 37
Insgesamt: 88
