Zum Hauptinhalt wechseln
How To Repair A Couch Cushion
Was du brauchst
  1. How To Repair A Couch Cushion, How To Repair A Couch Cushion: Schritt 1, Bild 1 von 1
    • Apply a thin layer of the anti-fray glue to both edges of the rip. Let it dry completely.
  2. How To Repair A Couch Cushion: Schritt 2, Bild 1 von 1
    • Fold the edges of the fabric over to make a clean edge and hide any fraying.
    • Crease the fold with your fingers.
  3. How To Repair A Couch Cushion: Schritt 3, Bild 1 von 1
    • Cut the upholstery thread to a length appropriate for the size of your rip.
    • The thread should match the color of the fabric as closely as possible.
    • Thread the needle and tie a double knot at the end.
  4. How To Repair A Couch Cushion: Schritt 4, Bild 1 von 2 How To Repair A Couch Cushion: Schritt 4, Bild 2 von 2
    • Hold the two edges of the rip together
    • Begin sewing ¾ of an inch from where the rip begins.
    • You might want to use a pin to hold the edges together while you sew
  5. How To Repair A Couch Cushion: Schritt 5, Bild 1 von 3 How To Repair A Couch Cushion: Schritt 5, Bild 2 von 3 How To Repair A Couch Cushion: Schritt 5, Bild 3 von 3
    • Continue sewing until you are past the rip. Knot and cut the excess thread.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Alexis
227 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-2, Green Winter 2015 Mitglied von Cal Poly, Team 24-2, Green Winter 2015
CPSU-GREEN-W15S24G2
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 47
Letzte 30 Tage: 95
Insgesamt: 17,021
