Zum Hauptinhalt wechseln
How To Repair A Rip In Chiffon Fabric
Was du brauchst
  1. How To Repair A Rip In Chiffon Fabric, How To Repair A Rip In Chiffon Fabric: Schritt 1, Bild 1 von 1
    • Locate the rip in the fabric.
  2. How To Repair A Rip In Chiffon Fabric: Schritt 2, Bild 1 von 1
    • Trim off any fraying at the tear.
    • Fold the fabric in half at the tear and cut off the fraying. This makes it easier to clip the smaller frayed fibers as well.
  3. How To Repair A Rip In Chiffon Fabric: Schritt 3, Bild 1 von 1
    • Fold the fabric in half at the rip so that the raw edges are right side together.
  4. How To Repair A Rip In Chiffon Fabric: Schritt 4, Bild 1 von 1
    • Find a permanent fabric adhesive.
  5. How To Repair A Rip In Chiffon Fabric: Schritt 5, Bild 1 von 1
    • Carefully apply the adhesive to the raw edges.
  6. How To Repair A Rip In Chiffon Fabric: Schritt 6, Bild 1 von 1
    • Keep the edges together until almost dry.
  7. How To Repair A Rip In Chiffon Fabric: Schritt 7, Bild 1 von 1
    • Then lay the cloth flat and push the edges together to make sure the ends stay together.
    • Let the adhesive dry completely.
    • At this point, if your tear/repair is large, you can find a patch that can cover the repair and glue it on.
    • Avoid ironing on the patch. This may cause even more damage to fabric as this material is already very delicate.
Abschluss
Now the damage done to your fabric should be contained and the material should be restored to working order. Hope this helped!
Manasa Dintakurthi
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 90
Letzte 30 Tage: 429
Insgesamt: 10,594
