Zum Hauptinhalt wechseln
How To Repair An Overheating D-LINK DIR-655 Wireless Router
Was du brauchst
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 1, Bild 1 von 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 1, Bild 2 von 2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 2, Bild 1 von 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 2, Bild 2 von 2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 3, Bild 1 von 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 3, Bild 2 von 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 3, Bild 3 von 3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 4, Bild 1 von 1
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 5, Bild 1 von 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 5, Bild 2 von 2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 6, Bild 1 von 1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 7, Bild 1 von 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 7, Bild 2 von 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 7, Bild 3 von 3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 8, Bild 1 von 1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: Schritt 9, Bild 1 von 1
    • Wipe away any dust from the the vents to ensure proper airflow.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-6, Green Fall 2015 Mitglied von Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Fixed my unit :-)
larry_wollen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 5,454
