Einleitung
If your Apple Watch's silicone band is torn, this guide provides step-by-step instructions for an effective repair. This method works for any Apple Watch model with a silicone band, helping you restore its integrity and prevent further damage.
The process includes carefully cleaning and bonding the torn area, with steps to ensure a smooth finish and a strong, lasting bond.
For best results, work in a well-lit, ventilated area, and handle UV-curable glue with care.
Follow each step closely to create a durable repair that restores your band’s usability and comfort.
Was du brauchst
Gently bend the silicone watch band to get an idea of the size/severity of the tear.
Gently bend the watch strap to expose the inner part of the tear and use an alcohol wipe to thoroughly clean the area surrounding and inside the tear.
Allow the silicone band to air dry until no longer visibly wet.
Bend the watch band to expose the inner part of the tear.
Apply the dot of glue to the inner part of the tear.
Release the band from the bent position so that it lies in its natural position.
Using a new toothpick, wipe away excess glue that may have splurged out of the tear on both sides of the band.
Wipe the toothpick across the glue from the inner part of the tear to the outer edge of the watch band to create a thin, even layer of glue across the outer surface of the tear.
If remaining texture from the dried glue is not aesthetically pleasing, carefully use a nail buffer to smooth out any excess texture. (optional)
Your Apple Watch band repair is complete. Allow the glue to fully cure before use, and avoid excessive water exposure.
