Zum Hauptinhalt wechseln
How To Replace An Air Conditioner Vent Cover
Was du brauchst
  1. How To Replace An Air Conditioner Vent Cover, Air Conditioner Vent Cover: Schritt 1, Bild 1 von 2 How To Replace An Air Conditioner Vent Cover, Air Conditioner Vent Cover: Schritt 1, Bild 2 von 2
    • Observe the structure of the air vent cover and the shape of the screws, and choose the right screwdriver.
    • Place a chair or ladder under the air outlet for easy access to the screws.
  2. How To Replace An Air Conditioner Vent Cover: Schritt 2, Bild 1 von 3 How To Replace An Air Conditioner Vent Cover: Schritt 2, Bild 2 von 3 How To Replace An Air Conditioner Vent Cover: Schritt 2, Bild 3 von 3
    • Use the screwdriver to loosen one screw on the right and one screw on the left side of the outlet vent cover.
    • Remove the air outlet from the wall by hand.
  3. How To Replace An Air Conditioner Vent Cover: Schritt 3, Bild 1 von 1
    • Take out the new air conditioner vent cover and confirm the correct orientation for replacement.
  4. How To Replace An Air Conditioner Vent Cover: Schritt 4, Bild 1 von 2 How To Replace An Air Conditioner Vent Cover: Schritt 4, Bild 2 von 2
    • Place the new air conditioner cover into the wall and line the screw holes up with the holes in the wall.
  5. How To Replace An Air Conditioner Vent Cover: Schritt 5, Bild 1 von 2 How To Replace An Air Conditioner Vent Cover: Schritt 5, Bild 2 von 2
    • Align the screws by hand first and tighten them gently.
    • Use a screwdriver to tighten the screws on the left and right sides in a clockwise direction.
Abschluss
Yuntian Shi
283 Reputation
1 Anleitung geschrieben
York University, Team E-24, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-24, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG24
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 54
Insgesamt: 5,601
