Einleitung
Have you ever broken or cracked the baskets on your skis? Use this guide to replace your worn baskets and return your skis to excellent working condition!
Was du brauchst
Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
Heat for no longer then three minutes.
Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
Reheat the replaced basket with a hair dryer for a minute.
After heating, allow the glue to cool and set for 10 minutes.
Eine weitere Person hat diese Anleitung absolviert.
