Zum Hauptinhalt wechseln
How To Replace The Inlet Valve In Your Washing Machine
Was du brauchst
    • Unplug the washing machine from the electrical outlet to avoid electric shock.
    • Turn off the water supply to the washer to prevent flooding.
    • Locate and remove the retaining screws or clips securing the top panel of the machine.
    • Lift or slide the top panel to expose the inlet valve assembly at the back.
    • Loosen and remove any screws or brackets holding the inlet valve in place.
    • Label or photograph the wire connections to ensure correct reassembly.
    • Slide off any wire connectors from the old valve.
    • Place a container or cloth beneath the internal hoses to catch spilling water.
    • Loosen and remove the hose clamps or clips from the valve’s outlet ports.
    • Slide each hose off the old inlet valve, being cautious of any water inside.
    • Identify and note the ports for pre-wash, main wash, and softener if your valve has multiple outlets.
    • Confirm the softener port has the correct internal nozzle or insert as required.
    • Attach each hose to the corresponding port on the replacement valve and secure the hose clamps.
    • Reinstall the valve in its original position and secure it with screws or brackets.
    • Reconnect the wire connectors in the same order you noted before.
    • Restore power and water, but do not fully reattach the top panel yet.
    • Select a short wash or pre-wash cycle to check for correct water flow and leaks.
    • Turn the dial to the main wash and softener programs to verify proper flow in each compartment.
    • Shut off the power once more and reinstall the machine’s top panel securely.
    • Observe any signs of water leakage before turning off the machine again.
    • Plug in your washer, turn on the water supply, and run a full wash cycle to confirm normal operation.
Abschluss
Replacing the inlet valve restores proper water flow to your washing machine and can resolve filling or leaking problems. Remember to follow all safety guidelines, and consult the manufacturer’s instructions to ensure compliance with any warranty conditions. If uncertain, contact a qualified service technician.
Ula Gantar
16.474 Reputation
81 Anleitungen geschrieben
ZEOS Slovenia Mitglied von ZEOS Slovenia
Local Repair Groups
2 Mitglieder
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 118
Insgesamt: 1,029
