Zum Hauptinhalt wechseln
How To Service Your Hair Dryer
Was du brauchst
    • Disconnect the hair dryer from the power source before starting any service.
    • Take off any filters or covers that come away without using any tools.
    • Locate and remove the four screws on the handle or housing with a screwdriver.
    • Gently separate the plastic housing by releasing any clips or tabs.
    • Be cautious not to force the plastic pieces to avoid cracks or damage.
    • Take photos or mark screw locations to simplify reassembly later.
    • Unscrew any additonal screws.
    • Lift the motor assembly gently, noting that it is attached to the heating element.
    • Handle the heating coils carefully because they are delicate and can break. Use scissors to help you with that.
    • Examine wires and coils for discoloration, burns, or loose connections.
    • Do not proceed if you observe melted components or severe damage.
    • Use a vacuum or brush to remove hair, dust, and other debris from the motor and grill.
    • Remove lodged particles gently using tweezers if required.
    • Apply a drop of machine oil to the small bearing on the shaft.
    • Rotate the shaft to distribute the oil and ensure smooth movement.
    • Return the motor and heating element to their original positions with wires secured.
    • Align and snap the housing panels back together carefully.
    • Insert and tighten all screws that were removed earlier.
    • Plug in the hair dryer briefly to check for proper airflow and any odd noises.
    • Unplug again if you detect burning smell or unusual sounds.
Abschluss
Maintaining your hair dryer regularly keeps it efficient and safe while diverting waste from disposal. Servicing the device could affect any existing warranties, so verify your coverage first. If you are ever uncertain or find major damage, consult a certified technician for further assistance.
Ula Gantar
2.809 Reputation
19 Anleitungen geschrieben
ZEOS Slovenia Mitglied von ZEOS Slovenia
Local Repair Groups
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 12
