Zum Hauptinhalt wechseln
How To Start Remote Viewfinder on Samsung WB150F
Was du brauchst
  1. How To Start Remote Viewfinder on Samsung WB150F, Power on the device: Schritt 1, Bild 1 von 2 How To Start Remote Viewfinder on Samsung WB150F, Power on the device: Schritt 1, Bild 2 von 2
    • Turn on the device by pressing the button thats labeled POWER on the top.
  2. How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: Schritt 2, Bild 1 von 2 How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: Schritt 2, Bild 2 von 2
    • Look at the wheel at the top
    • Scroll until the dot is at Wi-Fi
  3. How To Start Remote Viewfinder on Samsung WB150F: Schritt 3, Bild 1 von 3 How To Start Remote Viewfinder on Samsung WB150F: Schritt 3, Bild 2 von 3 How To Start Remote Viewfinder on Samsung WB150F: Schritt 3, Bild 3 von 3
    • Navigate using the Navigation wheel
    • Navigate until the blue glowing square is on Remote Viewfinder
    • Press OK
  4. How To Start Remote Viewfinder on Samsung WB150F, Setting Up: Schritt 4, Bild 1 von 1
    • If everything done correctly, You will be on this screen, Time to install the viewfinder app.
  5. How To Start Remote Viewfinder on Samsung WB150F, Finding the app: Schritt 5, Bild 1 von 1
    • Search up Remote ViewFinder on App Store/Play Store
  6. How To Start Remote Viewfinder on Samsung WB150F, Downloading the app: Schritt 6, Bild 1 von 1
    • When you found the app, Press the download button
    • If it is a cloud, It means it was installed before, You will not need a password to download it.
    • The App Is pretty outdated, I suggest using iOS 4-10, It wont work on newer iOS
    • An iPhone 5c or an iPad 4 works well.
  7. How To Start Remote Viewfinder on Samsung WB150F, Connecting: Schritt 7, Bild 1 von 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting: Schritt 7, Bild 2 von 2
    • Open up settings and go to the Wifi Tab
    • Connect your device to the cameras wifi.
    • The Wifi name should be the same as on the camera.
  8. How To Start Remote Viewfinder on Samsung WB150F, Starting the application: Schritt 8, Bild 1 von 1
    • Launch Remote Viewfinder on your device
  9. How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: Schritt 9, Bild 1 von 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: Schritt 9, Bild 2 von 2
    • Wait until its connected.
    • If you see the screen of your camera Your camera is connected (see step 10 for controls)
  10. How To Start Remote Viewfinder on Samsung WB150F, Controls: Schritt 10, Bild 1 von 1
    • Flash
    • Timer
    • Photo Size
    • Zoom
    • Shutter Button
    • Camera View
    • Tap the camera view to hide/show the menu.
Abschluss
Close the app, to disconnect your camera from the app
Artem Ivat
3.356 Reputation
13 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 1,488
