Zum Hauptinhalt wechseln
How To True A Bicycle Wheel
Was du brauchst
Einführungsvideo
  1. How To True A Bicycle Wheel, How To True A Bicycle Wheel: Schritt 1, Bild 1 von 1
    • Put the rim and align into the truing stand.
  2. How To True A Bicycle Wheel: Schritt 2, Bild 1 von 1
    • Second, grab lubricant.
  3. How To True A Bicycle Wheel: Schritt 3, Bild 1 von 1
    • Notice how each nipple is void of lube. In this step add the lube to each individual nipple.
  4. How To True A Bicycle Wheel: Schritt 4, Bild 1 von 1
    • Once you have completed the previous task, loosen the truing knob.
    • This will make the truing arms open.
    • Give it a spin! The centrifical force lubes up the threads, making it easier to begin truing.
    • Notice the spoke wrenches; they will be required in our next step.
  5. How To True A Bicycle Wheel: Schritt 5, Bild 1 von 1
    • Use the truing knob to determine how fine the truing arms (red) need to be. In this case, I am truing finely down to the millimeter.
  6. How To True A Bicycle Wheel: Schritt 6, Bild 1 von 1
    • Here the spoke tool (red) will be needed. After giving it a spin, I noticed that it deviated far too much to the left. You will know this by hearing which side scrapes against the truing arm. (orange)
    • Use the spoke wrench (red) to tighten the spokes (yellow). It is good practice to tighten the spoke before and after on the side that needs truing.
    • Lastly, keep truing tire until the range of deviation is good to you. This process for a "quick-fix" can be as little as 30min-1 hour.
    • Experienced cyclists may vary from days to weeks to completely true their tire.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Elijah W
187 Reputation
1 Anleitung geschrieben
Austin Community College, Team 22-10, Watkins Fall 2023 Mitglied von Austin Community College, Team 22-10, Watkins Fall 2023
AUSTINCC-WATKINS-F23S22G10
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 170
