Einleitung
This guide shows how to correctly operate and maintain foil sealers and vacuum machines for food storage. It also covers ways to keep them safe, clean, and in good working condition. Performing basic upkeep will help prolong their life and prevent common issues. Always verify your warranty and follow manufacturer guidelines before any intervention.
Was du brauchst
Schritt 2 Use a standard foil sealer
Position the open end of the bag over the heat strip and close the sealer firmly.
Listen for the click or watch for the indicator light signaling the seal is complete.
Use this type of sealer for items like freezer bags, dried food, or small snacks.
Schritt 3 Operate a hybrid vacuum sealer
Place specialty vacuum-friendly bags in the channel as standard plastic bags will not seal properly.
Press down on the lid to start the vacuum motor and wait for the seal to activate.
Schritt 4 Handle an advanced vacuum sealer
Use thicker bags designed specifically for vacuum sealing to ensure a proper seal.
Place the open end of the bag inside the vacuum channel and choose vacuum plus seal on the control panel.
Wait for the machine to draw out the air and automatically seal once the vacuum is strong enough.
Position multiple narrow bags side by side if the sealing bar allows simultaneous sealing.
Schritt 5 Vacuum sealing with marinade
Place raw meat or other items with marinade in a strong vacuum-rated bag.
Close the bag securely and activate the vacuum function to draw marinade into the food.
Schritt 7 Clean the vacuum channel
Use a mild or disinfectant cleaner if raw juices entered the vacuum chamber.
Wipe away residue carefully and ensure all surfaces are fully dry before reassembly.
Schritt 8 Rinse and replace the safety filter
Locate and remove the safety filter or foam element from the underside of the vacuum sealer.
Wash the foam filter with water, let it dry completely, and reinstall it in the channel.
Schritt 9 Inspect the gaskets and seals
Check the sealing gaskets or rubber parts for damage and ensure a snug fit to avoid air leaks.
Schritt 10 Practice sustainable maintenance
Use reliable bags and maintain your device regularly for long-lasting operations.
Seek help from authorized technicians if you encounter complex issues beyond basic maintenance.
These methods help you safely and effectively operate vacuum machines and foil sealers in a long-lasting manner. Proper cleaning and respectful handling of the sealing strip and vacuum chamber will keep your device working efficiently. Always verify your warranty rules before opening any appliance. A well-maintained machine is a dependable partner in preserving food quality and reducing waste.
