Einleitung
From time to time it can happen that the seam of your functional jacket gets detached, e.g. due to incorrect care or external influences. We will show you here in just a few steps how you can fix the seam again.
Was du brauchst
You’ll need a kitchen towel, an iron, matching thread and a sewing machine
Place a thin towel over the seam on your jacket and iron evenly. Be very careful not to hold the iron too long in any one place so that the fabric doesn’t get too hot — it’s better to check frequently under the towel to see if the seam has re-bonded and to press the iron down firmly. Ironing the seam helps it rebond before you sew it back together.
Thread the sewing machine with matching thread and carefully sew along the seam parallel to the zipper. Lock the seam by briefly stitching back and forth at the beginning and end of your line of sewing.
Finished! You did it.
100%
Daniel Schmid hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
