Einleitung
After years of use, you might need to replace the Klickfix mounting plate on your Aqua Box. It just takes a few steps—read on to find out how.
Was du brauchst
Loosen all 4 screws on the mounting plate by holding the nuts on the outside with a socket wrench #7 and unscrewing the screws with a standard Phillips #2 screwdriver.
To finish the repair follow the instructions in reverse order.
100%
Hier starten ›
