Einleitung
In this guide I will teach you how to repair a loose bike chain. Before we begin the guide you will need a socket wrench, gloves, and a bike stand (optional). A bike chain is a chain that connects the pedals to the rear wheel. When you rotate the pedals as you do when riding your bike, the energy created by the rider transfers to the rear wheel, thus allowing you to move forward.
Was du brauchst
Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
Pull the wheel back from the frame.
Hold the wheel in place while proceeding to the next step.
Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
After reading this guide you will never have trouble with a loose chain again.
2 weitere Personen haben diese Anleitung absolviert.
