Einleitung
This fix will help individuals fix the dents on their cars easily from home. The hardest part of this Fix is in fact our first step. When cutting a hole at the bottom of the pot and/or bucket you decide to use one must be both careful and patient, since we're cutting a hole in something. Having a helping hand in the process of taping the bucket to your car can also be very helpful, but not needed. Aside from that it isn't a fix that is too complicated for anyone to try!
Ersatzteile
Keine Ersatzteile angegeben.
Be sure that the bucket or pot is big enough to fit the vacuum that will be used for this procedure
Insert the vacuum into the hole at the bottom of the bucket to be sure it fits
If the hole is too small and the vacuum cannot fit within the hole, go back to step one and attempt to enlarge the hole
If the hole appears to be too large, one may want to consider going back to step one with a new bucket
Place the bucket over the dent that needs to be fixed
Start by lightly taping down the bucket with painters tape - this allows the bucket to be held up and allow the rest of the tapping easier to do
Go over the edges of the bucket with duct tape until you are sure that it is airtight onto the car
Place the vacuum into the hole at the bottom of the bucket
At this point be sure to allow some time for suction to occur and listen for a small popping noise
The popping noise that needs to be listened for is the dent in your car popping out from the suction of the vacuum
At times the way the vacuum is positioned can affect the suction
If after some time there is no popping noise, adjusting the placement of the vacuum is recommended
After adjusting the vacuum allow time for suction again and listen for a popping noise to know when your dent is fixed
2 weitere Nutzer haben diese Anleitung absolviert.
