Zum Hauptinhalt wechseln
How to Add a Hole to a Belt
Was du brauchst
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: Schritt 1, Bild 1 von 1
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: Schritt 2, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 2, Bild 2 von 2
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: Schritt 3, Bild 1 von 1
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: Schritt 4, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 4, Bild 2 von 2
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: Schritt 5, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 5, Bild 2 von 2
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: Schritt 6, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 6, Bild 2 von 2
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
Abschluss
After you complete the final step to your liking the fix is done.
Alexa Velazquez
133 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021 Mitglied von UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G25
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 1,322
