Zum Hauptinhalt wechseln
How to Add a Hole to a Belt
Was du brauchst
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: Schritt 1, Bild 1 von 1
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: Schritt 2, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 2, Bild 2 von 2
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: Schritt 3, Bild 1 von 1
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: Schritt 4, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 4, Bild 2 von 2
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: Schritt 5, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 5, Bild 2 von 2
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: Schritt 6, Bild 1 von 2 How to Add a Hole to a Belt: Schritt 6, Bild 2 von 2
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
Abschluss
After you complete the final step to your liking the fix is done.
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021 Mitglied von UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G25
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 43
Letzte 30 Tage: 141
Insgesamt: 2,821
