Einleitung
This guide will show how to adjust the browning dial in a Black and Decker TR1278B toaster.
Was du brauchst
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
