Zum Hauptinhalt wechseln
How to Adjust Cantilever Bicycle Brakes
Was du brauchst
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: Schritt 1, Bild 1 von 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: Schritt 1, Bild 2 von 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: Schritt 1, Bild 3 von 3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: Schritt 2, Bild 1 von 2 How to Adjust Cantilever Bicycle Brakes: Schritt 2, Bild 2 von 2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: Schritt 3, Bild 1 von 3 How to Adjust Cantilever Bicycle Brakes: Schritt 3, Bild 2 von 3 How to Adjust Cantilever Bicycle Brakes: Schritt 3, Bild 3 von 3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: Schritt 4, Bild 1 von 1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: Schritt 5, Bild 1 von 2 How to Adjust Cantilever Bicycle Brakes: Schritt 5, Bild 2 von 2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: Schritt 6, Bild 1 von 2 How to Adjust Cantilever Bicycle Brakes: Schritt 6, Bild 2 von 2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: Schritt 7, Bild 1 von 2 How to Adjust Cantilever Bicycle Brakes: Schritt 7, Bild 2 von 2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: Schritt 8, Bild 1 von 1
    • Flip the bike back onto its wheels.
Abschluss
Go ride your bike!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S4-G21, Woodhouse Fall 2020 Mitglied von York University, Team S4-G21, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S4G21
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 806
