Zum Hauptinhalt wechseln
How to Adjust a Violin Bow
  1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: Schritt 1, Bild 1 von 2 How to Adjust a Violin Bow, How to Adjust a Violin Bow: Schritt 1, Bild 2 von 2
    • Identify the adjusting screw at the butt end of the bow.
  2. How to Adjust a Violin Bow: Schritt 2, Bild 1 von 1
    • Carefully unscrew the adjusting screw .
  3. How to Adjust a Violin Bow: Schritt 3, Bild 1 von 1
    • Once you fully unscrew the adjusting screw, carefully remove both the frog and the adjusting screw from the bow.
  4. How to Adjust a Violin Bow: Schritt 4, Bild 1 von 1
    • While not allowing the hair to become tangled, insert a small part of the adjusting screw so that only a small portion of the tip is seen. You do not need to screw the adjusting screw into the eyelet.
  5. How to Adjust a Violin Bow: Schritt 5, Bild 1 von 2 How to Adjust a Violin Bow: Schritt 5, Bild 2 von 2
    • Carefully move the adjusting screw to tighten the eyehole, moving in a clockwise direction. To loosen, move the eyehole in a counter-clockwise direction.
    • Do not screw more than 180 degrees during adjustment to ensure you do not damage the bow.
  6. How to Adjust a Violin Bow: Schritt 6, Bild 1 von 1
    • Once you have either tightened or loosened the eyehole by 180 degrees, remove the adjusting screw from the eyehole.
    • Once you have finished, make sure the hairs are not tangled and have not become damaged during the adjusting process.
Abschluss
Julia Kellum
142 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 928
