Einleitung
Use this guide to replace the rear cover adhesive in your Google Pixel 9 Pro XL.
Note: This guide should be followed during reassembly, after you've completed your repair and are about to reattach the rear cover.
Was du brauchst
Use a spudger to scrape up and remove all the old rear cover adhesive from the perimeter of the frame.
Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
Repeat the previous step to remove all the rear cover adhesive and its residue from the underside of the rear cover.
Remove the larger clear liner from the rear cover adhesive.
Carefully place the adhesive onto the frame so the large cutout goes over the cameras. Use the frame's lip to help position the sheet.
Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
Grip the top left corner of the large blue liner with tweezers or your fingers and remove the liner.
Remove any liners from the underside of the rear cover, near the camera cutout area.
Apply a suction handle to the back of the rear cover, as close to the center of the right edge as possible.
Prop up the rear cover just to the right of your phone.
Reconnect the rear cover press connector to the logic board.
Put the cable cover into place.
Use a Torx Plus 3IP screwdriver to install the two 5.2 mm‑long screws securing the cable cover.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Grip one of the pull tabs on the left side of the frame and remove it.
With one hand, use the suction handle to hold the rear cover over your phone. Remember that the rear cover is attached to the phone with a delicate cable.
With your free hand, use tweezers or your fingers to remove the remaining blue liner and expose the rear cover adhesive.
Lay the rear cover onto the frame and firmly press it into place.
Firmly squeeze around the entire perimeter of the rear cover to secure it with the adhesive.
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
5 weitere Personen haben diese Anleitung absolviert.
