Zum Hauptinhalt wechseln
How to Calibrate a Frigidaire Oven That Doesn't Heat at Correct Temperature
Videoanleitung
Diese Anleitung wurde von einem YouTube-Video übertragen.
Was du brauchst
    • Acquire a metal oven thermometer rated for high temperatures.
    • Do not use an infrared thermal gun because it measures surface heat, not cavity temperature.
    • Locate the small sensor rod in the upper back corner of the oven cavity.
    • Place the thermometer on the rack beside the sensor, ideally in the back left corner.
    • Close the door and set Bake to 375 °F or 400 °F.
    • Allow the oven to run for at least 20 minutes, preferably 30 minutes, after Preheat completes.
    • Confirm the heating element has cycled off before reading the thermometer.
    • Wear heat-resistant gloves and keep hands clear of the hot element.
    • Record the stabilized thermometer temperature once it holds steady.
    • Subtract the actual reading from the set temperature to find the difference.
    • Plan to raise or lower the offset by this difference when programming.
    • Some control boards only adjust in 5 °F, 10 °F, 15 °F, or 25 °F increments.
    • Press Cancel or turn the selector knob to Off to shut the oven down.
    • Let the oven cool slightly before touching the control panel.
    • Press and hold the Bake button for 5–10 seconds until the display shows 0 °F.
    • Release the button when 0 °F appears to enter calibration mode.
    • If the display does not change, proceed to the alternate method.
    • Press Bake to wake the control, then turn the temperature to 550 °F.
    • Release the knob or button, then press and hold Bake for 5 seconds.
    • If 0 °F does not appear, release Bake, wait one second, and hold it again for 5 seconds.
    • Repeat the sequence until the calibration screen appears.
    • Use the Up and Down arrow keys to change the displayed temperature offset.
    • Positive numbers make the oven hotter; negative numbers cool it down.
    • Set the offset equal to the difference measured earlier without exceeding the board limit.
    • Adjust quickly because some boards time out in a few seconds.
    • Stop pressing keys and wait about 5–10 seconds for the display to return to normal.
    • The control stores the new offset automatically when the display resets.
    • Repeat the temperature test to verify the oven now matches the set temperature.
    • If the oven remains off by more than 100 °F, the temperature sensor or control board may be faulty.
    • An oven that stalls below 250 °F despite calibration typically needs electronic repair.
Abschluss
Your Frigidaire oven should now reach the temperature shown on its display. Re-check the temperature whenever you change cookware or notice inconsistent baking, and remember that extreme deviations usually point to a failing sensor or control board that will need replacement.
Ben Schlichter
6.532 Reputation
224 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 38
Letzte 30 Tage: 226
Insgesamt: 447
