Einleitung
Are your Lexus keyfob buttons not responding anymore? Use this guide to learn how to open the keyfob and swap out the buttons. The only tool you will need in this guide is your keyfob!
Was du brauchst
Place the keyfob with the removable metal key facing towards you.
With the button side facing you, pull the metal latch down towards you to pull out the key.
With the exposed corner facing you, place the metal key into the slot.
Turn the key sideways to open the keyfob.
Rotate the front plate, the broken buttons should fall out with ease.
Replace the broken buttons as necessary.
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
