Einleitung
Use this guide to replace the mortise lock and cylinder of the door lock.
Door lock details tend to deform as a result of long-term use, this can lead to the door lock becoming unusable. Hence, you may want to consider changing details like mortise lock and cylinder in order to return the door lock to a working condition.
Was du brauchst
Determine the position of the screws on both door handles and the front plate.
Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
Grasp the mortise lock on either side and pull it out from the edge of the door.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
