Zum Hauptinhalt wechseln
How to Change Strings on a Ukulele
Was du brauchst
  1. How to Change Strings on a Ukulele, String: Schritt 1, Bild 1 von 1
    • Start by loosening the string you are trying to replace by twisting the pegs.
    • The G and C tuning pegs turn up to tighten and down to loosen while the E and A tuning pegs turn down to tighten and up to loosen.
  2. How to Change Strings on a Ukulele: Schritt 2, Bild 1 von 1
    • Next, grab the new string you are using to replace.
    • The packaging will inform you of which string replaces which note—some are different than others so pay attention!
  3. How to Change Strings on a Ukulele: Schritt 3, Bild 1 von 1
    • Feed the string through the tie block.
    • Remember to leave slack.
  4. How to Change Strings on a Ukulele: Schritt 4, Bild 1 von 1
    • Wrap the string over the tie block and back underneath itself.
  5. How to Change Strings on a Ukulele: Schritt 5, Bild 1 von 2 How to Change Strings on a Ukulele: Schritt 5, Bild 2 von 2
    • Recross the string over itself again, looping it two or three more times.
  6. How to Change Strings on a Ukulele: Schritt 6, Bild 1 von 1
    • Pinch the string and pull tightly.
  7. How to Change Strings on a Ukulele: Schritt 7, Bild 1 von 1
    • Now, fasten the string back to the headstock. To do this, feed the string through the hole in the turning peg.
  8. How to Change Strings on a Ukulele: Schritt 8, Bild 1 von 1
    • Twist again to tighten and cut off extra string once complete.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 577
