Einleitung
Use this guide to remove burnt-on food, greasy residue, and burner rings from a glass cooktop using a cooktop cleaner, a scrubbing pad, and a razor scraper. This method can dramatically brighten a heavily soiled stove, but some permanent discoloration, especially in the center from low-quality pans leaving metal deposits, may not fully come out.
Was du brauchst
Schritt 1 Prepare the stove and workspace
Turn off the stove, make sure the surface is completely cool, and clear everything off the cooktop.
Schritt 2 Gather tools and cleaning supplies
Get a glass cooktop cleaner and polish, glass cooktop scrubbing pads, and a razor scraper with fresh blades.
Get a microfiber cloth for wiping up residue, and a container of water for rinsing the pad if needed.
Schritt 3 Know what discoloration you may not remove
Check the center area for dull, gray discoloration that doesn’t look like raised food or grease.
Schritt 4 Apply cooktop cleaner for the first pass
Apply a generous amount of glass cooktop cleaner and polish across the cooktop.
Schritt 5 Scrub the cooktop and focus on burner rings
Use a glass cooktop scrubbing pad to scrub the entire cooktop, pressing firmly to cut through burnt-on buildup.
Add extra cleaner directly onto the burner rings that are heavily stained, and scrub them longer than the rest of the surface.
Scrub for several minutes, spending about five minutes overall and up to seven minutes on the burners for heavy buildup.
Schritt 6 Scrape burnt-on residue with a razor scraper
Hold the razor scraper at a shallow angle and scrape around the burner rings and across stuck-on areas to lift the crud.
Start around a 15° to 20° angle rather than scraping straight down at 90°.
Increase to a steeper angle, up to about 75°, for stubborn debris that won’t release at a shallow angle.
Schritt 7 Inspect the first pass and decide what to repeat
Wipe away loosened cleaner and debris with a microfiber cloth to see what’s left on the glass.
Check that the deepest cooked-on deposits are gone, even if lighter residue and haze remain.
Schritt 8 Do a second cleaning pass
Clean out the scrubbing pad, apply more cooktop cleaner, and scrub the cooktop again to remove remaining residue.
Spend several minutes scrubbing, because this pass is meant to remove leftover haze and smaller stuck-on spots.
Schritt 9 Scrape again for remaining stubborn spots
Use the razor scraper again over any remaining burnt spots and residue after the second scrub.
Schritt 10 Wipe down and compare results
Wipe the cooktop clean with a microfiber cloth to remove all cleaner and loosened debris.
Compare the cooktop to its starting condition and look for clearer burner rings and a brighter overall surface.
If burner rings or burnt spots still show, repeat the cleaner-and-scrub pass and spot-scrape again rather than trying to remove everything in a single aggressive session. If the center area stays discolored but feels smooth, it may be permanent metal deposit staining from cookware, not removable food residue. Store the razor scraper safely, and dispose of used blades in a puncture-resistant container. Repair didn't go as planned? Ask our Answers community for help.
