Zum Hauptinhalt wechseln
How to Clean Canon PIXMA MP190 Print Head Nozzle
  1. How to Clean Canon PIXMA MP190 Print Head Nozzle, Turn printer on.: Schritt 1, Bild 1 von 1
    • The printer needs to be on in order to change the ink cartridges.
  2. How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: Schritt 2, Bild 1 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: Schritt 2, Bild 2 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: Schritt 2, Bild 3 von 3
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: Schritt 3, Bild 1 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: Schritt 3, Bild 2 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: Schritt 3, Bild 3 von 3
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
  4. How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: Schritt 4, Bild 1 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: Schritt 4, Bild 2 von 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: Schritt 4, Bild 3 von 3
    • Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle.
    • Repeat until the nozzle appears free of any ink and debris.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Michigan Tech, Team 1-5, Lauer Fall 2014 Mitglied von Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
is ther an easy way to gain access to the roller at the rear of the machine to clean it
hope342 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 48
Insgesamt: 6,268
