Einleitung
The needle that punctures the K-Cup beverage canister can sometimes become clogged with coffee particles. Take caution as this needle is very sharp and can cut skin.
Was du brauchst
Remove K-Cup Pack Holder Assembly by pinching the left and right sides to release clamp. Wiggle slightly to remove
Pull and snap apart the funnel from the K-Cup Pack Holder (If this is the first time separating the Pack Holder Assembly, more force may be required)
Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
Flip K-Cup Pack Holder and repeat
With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
Once reassembled, run the brewer once or twice with just water to cleanse the system.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
The bottom needle is loose on small piece of plastic is this normal or broke?
