Zum Hauptinhalt wechseln
How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller
Was du brauchst
  1. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: Schritt 1, Bild 1 von 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 6.0 mm screws located on the back of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 2, Bild 1 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 2, Bild 2 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 2, Bild 3 von 3
    • Separate the front and the back of the controller by pulling both pieces apart at the same time.
    • Be very careful and gentle when pulling the shells apart because the blue ribbon can become detached and damaged.
    Frag FixBot
  3. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 3, Bild 1 von 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 3, Bild 2 von 2
    • Carefully unplug the blue ribbon from the body of the controller shell.
    Frag FixBot
  4. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 4, Bild 1 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 4, Bild 2 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 4, Bild 3 von 3
    • Remove the left and right triggers by wiggling the buttons sideways until they are completely off.
    Frag FixBot
  5. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 5, Bild 1 von 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 5, Bild 2 von 2
    • Take the Q-tip and soak it into the isopropyl alcohol.
    • Clean around the trigger button area as well as under and above the rubber padding.
    Frag FixBot
  6. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 6, Bild 1 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 6, Bild 2 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 6, Bild 3 von 3
    • Put the L2 and R2 buttons back into place by simply forcing them into position until properly locked.
    Frag FixBot
  7. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 7, Bild 1 von 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 7, Bild 2 von 2
    • Attach the blue ribbon back into its original location so that the two shells of the controller are connected.
    Frag FixBot
  8. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 8, Bild 1 von 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 8, Bild 2 von 2
    • Put the two shells of the controller together by pushing them together at the same time.
    Frag FixBot
  9. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 9, Bild 1 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 9, Bild 2 von 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: Schritt 9, Bild 3 von 3
    • Screw the four 6.0mm screws on the back of the controller using the Phillips #00 screwdriver.
    Frag FixBot
Ziellinie
9 weitere Personen haben diese Anleitung absolviert.
York University, Team 2-5, O'Regan Fall 2023 Mitglied von York University, Team 2-5, O'Regan Fall 2023
YORK-O'REGAN-F23S2G5
1 Mitglied
3 Anleitungen geschrieben
1 Kommentar zur Anleitung
سلام اون نظری که واستون گذاشتم رسید به دستتون گفتم اگر نشه درست نشه باید چیکار کنیم
ایمان هاشمی - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 110
Letzte 30 Tage: 541
Insgesamt: 12,951
