Einleitung
Use this guide as a reference on how to maintain and repair a Lekker Switch - Linear45 (L45) switch on a Wooting Keyboard.
In the case that users face inconsistency or other issues with key presses, there is a possibility that dust and debris may be interfering with the keyboard sensor and the magnet inside the switch. Cleaning out the switch interior can fix this unless there is a software issue.
If problematic key presses are caused by a cracked switch housing or the spring is worn out, a switch and/or spring replacement will be required. Refer to the guide instructions as they point out which steps relate to each target fix.
Was du brauchst
Align the keycap puller so the prongs wrap underneath the sides of the keycap, then pull up to remove the keycap.
Align the prongs of the switch puller so it clips underneath the grooves of the north and south side of the switch, then pull up.
Identify the four prongs on the switch opener.
Align the switch onto the switch opener so that it sits flush on the prongs, then push down on the switch to disassemble the switch.
Identify the various switch components and the order of construction (from left to right or bottom to top): bottom housing, spring, stem, top housing. Separate them from the switch.
Identify the individual parts and see if any parts are dirty to the degree that it could interfere with the magnet sensor.
Clean out the dust or debris thoroughly with a cotton swab.
Hold the bottom housing such that the inner cylinder faces up.
Slip the spring onto the cylinder.
Place the stem so the magnet faces the bottom housing, and the stem mount faces up.
Orient the stem so the side notches at the top face the sides of the switch.
Place the top housing on top of the stem and align it so the LED window faces north.
Clip the switch parts together into place.
Align the switch into the board such that the LED window is facing north.
Push down so the switch clips into place and isn’t loose.
Align the keycap so it faces the correct orientation.
Press down the keycap onto the switch.
