Zum Hauptinhalt wechseln
How to Clean a Clouded Glass Oven Door
Was du brauchst
  1. How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: Schritt 1, Bild 1 von 3 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: Schritt 1, Bild 2 von 3 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: Schritt 1, Bild 3 von 3
    • Open the oven door until it lays flat.
  2. How to Clean a Clouded Glass Oven Door: Schritt 2, Bild 1 von 3 How to Clean a Clouded Glass Oven Door: Schritt 2, Bild 2 von 3 How to Clean a Clouded Glass Oven Door: Schritt 2, Bild 3 von 3
    • Add a tablespoon of baking soda to a medium size bowl.
    • Pour 1 cup of vinegar into the bowl.
    • Mix the solution together.
  3. How to Clean a Clouded Glass Oven Door: Schritt 3, Bild 1 von 3 How to Clean a Clouded Glass Oven Door: Schritt 3, Bild 2 von 3 How to Clean a Clouded Glass Oven Door: Schritt 3, Bild 3 von 3
    • Pour the mix on the open oven glass door, making sure to cover the entire area.
    • Leave it for about 45 minutes
    • You might notice the mixture bubbling and rising. Wait until it simmers down but continues to bubble.
  4. How to Clean a Clouded Glass Oven Door: Schritt 4, Bild 1 von 3 How to Clean a Clouded Glass Oven Door: Schritt 4, Bild 2 von 3 How to Clean a Clouded Glass Oven Door: Schritt 4, Bild 3 von 3
    • 30 minutes - 1 hour later, use a stainless steel sponge to scrub the glass door. The mix aids in loosening deep stains.
    • Keep scrubbing until the surface feels clean and the stains are gone.
    • If your arm is getting tried from the intense scrubbing, take a break!
  5. How to Clean a Clouded Glass Oven Door: Schritt 5, Bild 1 von 3 How to Clean a Clouded Glass Oven Door: Schritt 5, Bild 2 von 3 How to Clean a Clouded Glass Oven Door: Schritt 5, Bild 3 von 3
    • Once the stains are gone, use a towel to clean off the residue and remaining mixture.
    • Rinse the residue off the towel and repeat until the door is entirely clean of dirt and mixture residue.
  6. How to Clean a Clouded Glass Oven Door: Schritt 6, Bild 1 von 3 How to Clean a Clouded Glass Oven Door: Schritt 6, Bild 2 von 3 How to Clean a Clouded Glass Oven Door: Schritt 6, Bild 3 von 3
    • Add soap and water to a sponge and gently clean the oven door.
    • Use a damp towel to wipe off the soap, then use a paper towel to thoroughly dry the oven glass door, ensuring there is no leftover water.
Abschluss
Enjoy you clean glass oven door!
Eine weitere Person hat diese Anleitung absolviert.
York University, Team 2-1, O'Regan Winter 2024 Mitglied von York University, Team 2-1, O'Regan Winter 2024
YORK-O'REGAN-W24S2G1
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 39
Insgesamt: 1,101
