Einleitung
This guide is for users who are unfamiliar with disassembling the Dirt Devil Vacuum Cleaner model. This includes the basic steps on how to disassemble the vacuum model, clean the roller brush, and reassemble the vacuum. These simple instructions are for users who have a problem with the vacuum roller brush not spinning and want a quick repair on their own. The special requirement of this guide is to know how to loosen the screw on the bottom plate and tighten the screw.
Was du brauchst
Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
Check if the belt is attached.
Check if the motor part is well inserted with the belt attached to the roller brush.
Eine weitere Person hat diese Anleitung absolviert.
5 Kommentare zur Anleitung
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
in the front there are to wheels, pop them out and you will see the other 2 screws
There must be different versions. Mine has eight very obvious screws and looks like the one in the guide. The front was still stuck, and I thought there might be screws under the wheels, but there were not. There were four very stubborn plastic clips at the front. I ended up running a prying tool between the two parts and getting the clips free.
Obviously, the comment I'm replying to was from a long time ago, but maybe I can help someone else.
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
