Zum Hauptinhalt wechseln
How to Clean a Filter on a MAYTAG Laundry Machine
Was du brauchst
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 1, Bild 1 von 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 1, Bild 2 von 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 1, Bild 3 von 3
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 2, Bild 1 von 3 How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 2, Bild 2 von 3 How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 2, Bild 3 von 3
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 3, Bild 1 von 1
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 4, Bild 1 von 3 How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 4, Bild 2 von 3 How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 4, Bild 3 von 3
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: Schritt 5, Bild 1 von 1
    • Screw the filter clockwise back into place.
Ziellinie
Kaelyn Taing
121 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 50-50, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 50-50, Briggs Fall 2022
CSULA-BRIGGS-F22S50G50
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 120
Letzte 30 Tage: 462
Insgesamt: 7,256
