Zum Hauptinhalt wechseln
How to Clean a Kitchen Aerator
Was du brauchst
  1. How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: Schritt 1, Bild 1 von 2 How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: Schritt 1, Bild 2 von 2
    • Shut off valves that are located under the sink and position faucet in the center to drain remaining water.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Clean a Kitchen Aerator: Schritt 2, Bild 1 von 1
    • Avoid dropping small parts down the sink by covering the surface of the holes.
    Frag FixBot
  3. How to Clean a Kitchen Aerator: Schritt 3, Bild 1 von 1
    • Unscrew and remove aerator with a wrench.
    Frag FixBot
  4. How to Clean a Kitchen Aerator: Schritt 4, Bild 1 von 1
    • Clean aerator by soaking it in white vinegar overnight in a bowl or cup.
    Frag FixBot
  5. How to Clean a Kitchen Aerator: Schritt 5, Bild 1 von 1
    • Dry off aerator with a towel.
    Frag FixBot
  6. How to Clean a Kitchen Aerator: Schritt 6, Bild 1 von 1
    • Use a wrench to screw back on the aerator to the faucet.
    Frag FixBot
  7. How to Clean a Kitchen Aerator: Schritt 7, Bild 1 von 1
    • Slowly turn back on water valves to check for improves water pressure.
    • Make sure sink is cleared and components of faucet that were removed are sealed tight.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
83 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 141
Insgesamt: 2,006
