Zum Hauptinhalt wechseln
How to Clean a Mainstays Coffee Maker Water Tube
Was du brauchst
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: Schritt 1, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: Schritt 1, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: Schritt 1, Bild 3 von 3
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 2, Bild 1 von 2 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 3, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 3, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 3, Bild 3 von 3
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 4, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 4, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 4, Bild 3 von 3
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 5, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 5, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 5, Bild 3 von 3
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 6, Bild 1 von 2 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 6, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 7, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 7, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 7, Bild 3 von 3
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 8, Bild 1 von 2 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 8, Bild 2 von 2
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 9, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 9, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 9, Bild 3 von 3
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 10, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 10, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 10, Bild 3 von 3
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 11, Bild 1 von 1
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 12, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 12, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 12, Bild 3 von 3
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 13, Bild 1 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 13, Bild 2 von 3 How to Clean a Mainstays Coffee Maker Water Tube: Schritt 13, Bild 3 von 3
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: Schritt 14, Bild 1 von 1
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
Abschluss
UC Davis, Team 4-9, Andersen Winter 2024 Mitglied von UC Davis, Team 4-9, Andersen Winter 2024
UCD-ANDERSEN-W24S4G9
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 30
Insgesamt: 209
