Einleitung
Cleaning a snowblower’s carburetor helps to maintain its performance and prevent issues such as starting problems, fuel-related issues, and poor performance due to the buildup of debris and impurities in the fuel. Utilize this step-by-step guide as a resource to effectively maintain the carburetor for peak performance.
Make: YardWork
Model: LH3185A
Was du brauchst
Block the gas from coming out of the fuel tank using a locking plier.
Remove another two support bolts from the outer shield using a Phillips head screwdriver.
Loosen the handlebar by turning the knob counterclockwise until there's enough room to safely remove the shield.
Remove the bolt that holds the reservoir in place using a 13mm socket or spanner.
Clean the inside of the reservoir, the rubber, and the jet using the carburetor cleaner.
