Zum Hauptinhalt wechseln
How to Clean a YardWork LH3185A Snow Blower Carburetor
Was du brauchst
  1. How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 1, Bild 1 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 1, Bild 2 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 1, Bild 3 von 3
    • Block the gas from coming out of the fuel tank using a locking plier.
    • Alternatively, some snowblowers come with a shut-off valve to lock off the gas line.
  2. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 2, Bild 1 von 2 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 2, Bild 2 von 2
    • Remove the stop key by pulling outwards.
  3. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 3, Bild 1 von 1
    • Remove the choke key using a flat screwdriver.
  4. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 4, Bild 1 von 2 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 4, Bild 2 von 2
    • Remove the two support bolts from the outer shield using an 8 mm socket.
  5. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 5, Bild 1 von 1
    • Remove another two support bolts from the outer shield using a Phillips head screwdriver.
  6. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 6, Bild 1 von 1
    • Loosen the handlebar by turning the knob counterclockwise until there's enough room to safely remove the shield.
  7. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 7, Bild 1 von 2 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 7, Bild 2 von 2
    • Remove the inner switch using the 8mm socket.
  8. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 8, Bild 1 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 8, Bild 2 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 8, Bild 3 von 3
    • Remove the bolt that holds the reservoir in place using a 13mm socket or spanner.
    • Gas can leak when removing the jet, so have a bucket or towel in place.
  9. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 9, Bild 1 von 1
    • Remove the reservoir by pulling downwards.
  10. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 10, Bild 1 von 2 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 10, Bild 2 von 2
    • Clean the jet nozzle (all three holes) using a pin or small wire.
  11. How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 11, Bild 1 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 11, Bild 2 von 3 How to Clean a YardWork LH3185A Snow Blower Carburetor: Schritt 11, Bild 3 von 3
    • Clean the inside of the reservoir, the rubber, and the jet using the carburetor cleaner.
    • When reassembling the reservoir, it is crucial to carefully position the rubber component. Improper alignment of the rubber, combined with excessive tightening of the bolt, can result in damaging the rubber seal.
Abschluss
Demitri Roopnarine
293 Reputation
1 Anleitung geschrieben
York University, Team A-7, Allen Summer 2023 Mitglied von York University, Team A-7, Allen Summer 2023
YORK-ALLEN-SU23SAG7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 298
