Einleitung
Tired of lackluster cuts from dull Andis Hair Clippers? This iFixit Fast Fix is your one-stop shop for restoring their sharpness! We'll guide you through the entire process, from identifying tell-tale signs of a dull blade to safe cleaning and sharpening techniques. Get ready to transform your clippers from frustration to flawless cuts, all in a quick and easy fix!
Was du brauchst
Einführungsvideo
Use a Phillips #0 screwdriver to loosen the set screws by turning them left.
Remove the blade from your clipper.
Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present.
Take a clean lint free towel and dry the blade.
While drying, rub the blade in all directions applying light pressure to remove residue and polish the blade.
Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade.
Place your blades back into position and insert your set screws into the proper holes. Use a Phillips #0 screwdriver to secure the screws.
Now that your clippers are clean and sharp, they're ready to tackle any haircut with ease. Remember to oil them regularly and repeat this cleaning process every few haircuts to maintain optimal performance. Enjoy using your freshly sharpened clippers!
Eine weitere Person hat diese Anleitung absolviert.
