Einleitung
Do you ever find your scroll wheel getting stuck often? You may need to clean that dusty and grimy wheel to help you gain that edge in games, make you more efficient in your work documents, and much more!
Was du brauchst
Use a Phillips #0 screwdriver to remove the stickers that are hiding the screws.
Use a spudger to pry along the center seam of the mouse.
Open the outer casing of the mouse.
Remove the wires from the white crimp headers in order to separate the upper and lower housing units of the mouse.
Take a cotton swab and lightly remove any dirt or debris around the pin connections of the scroll wheel.
5 weitere Personen haben diese Anleitung absolviert.
