Einleitung
. You want to do this maintenance to pass smog, reduce rough idles, and whenever you replace your EGR valve, you want to clean out the ports and replace the gaskets as well. This service is more of a preventative maintenance, if you have any check engine lights regarding the EGR system, read the codes and start diagnosing from there.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the cleaning yourself.
Torque specs:
- 8.7 ft. lbs - EGR passage bolts
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
Was du brauchst
Videoanleitungen
0 Kommentare
