Was du brauchst
Insert the Jimmy into one of the two notches on the lamp door's top edge.
Then use light force on the Jimmy to pry the latch away from the door.
If necessary, insert the Jimmy into the second latch and separate it from the projector.
Remove the door away from the projector by hand.
Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
Then pull the plug away from the projector.
Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
Pull on the bottom plastic tab and remove the lamp by hand.
Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
