Einleitung
How to clear calculations on your TI-84 Plus CE. WARNING! THIS WILL REVERT ALL SETTINGS TO FACTORY DEFAULT!!
MEM is the second function of the plus sign, so push 2nd, then the plus sign.
You can also push the "7" key on your calculator
You can also push the "2" key on your calculator
Congratulations! You are complete!
This is very easy once you get the hang of it. I remember “2nd, Plus Sign, 7, 1, 2”.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Will it remove my newly installed apps and games such as Super Mario or Pac-Man?
please answer with dereklytle@student.godleyisd.net
Hi Derek,
Yes. The calculator will be restored to factory settings. It will be as if you just purchased the calculator.
having students clear the ram before a test has been my practice before a test/quiz...but on the TI 84CE if it is low battery and the students try to reset it it just gives a warning of battery too low. Students still have enough 'juice' to use it but I don't ever see the magical words "ram cleared"...do the TI 84CE calculators still clear the ram if it has a very low battery?
