Zum Hauptinhalt wechseln
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: Schritt 1, Bild 1 von 1
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: Schritt 2, Bild 1 von 1
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: Schritt 3, Bild 1 von 2 How to Clear a blocked, or clogged sink: Schritt 3, Bild 2 von 2
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: Schritt 4, Bild 1 von 1
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: Schritt 5, Bild 1 von 1
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: Schritt 6, Bild 1 von 1
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: Schritt 7, Bild 1 von 1
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
Abschluss
Your sink should now be free of obstructions or clogs in the pipes.
4 weitere Personen haben diese Anleitung absolviert.
Pasco Hernando, Team 5-1, Prince Fall 2015 Mitglied von Pasco Hernando, Team 5-1, Prince Fall 2015
PHSC-PRINCE-F15S5G1
1 Mitglied
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 81
Insgesamt: 2,921
