Einleitung
Entferne die Folie im Innern des Rückdeckels und du erhältst einen Blick ins Innere des Phablets!
Was du brauchst
Videoanleitungen
Um dein Gerät wieder zusammen zu setzen folge den Schritten in umgekehrter Reihenfolge.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
3 Kommentare
Hi nice tutorial. A little off topic....do you know how to fix a note 5 that says it is overheating when it is not. The phone does not charge as well shows a triangle with a thermometer and the charging indicator blinks
doyin ayoola - Antwort
Simple. You just arm it and clip the red wire with pliers :D Yeah kidding obviously. Try a new battery. It's an accessory.
Deyan Dobromirov (dvd_video) - Antwort
I'm replacing the back cover today on my note 5. I found another note 5that has a cracked LCD so I bought it for $20. As I was taking my broken one off the the color meterial started to peel and I started to have the same kinda idea. I went online to see if they sold custom back plates with cool designs but I could not find any. So I picked one out and with the help of photo shop made it look a little nicer. A older link picture from my favorite game Zelda.
I'm going to try and get a vinyl sticker made out of it and stick it to the back cover and install it on my old note 5. Any advice on what I should use to make it stick or any issues you might see with a over heating issue down the road. I was planning on selling it but if this works the way I want it to I'll proble end up keeping it or maybe even doing it to my note 8.
Jesse King - Antwort
