Einleitung
If the fit of your shirt sleeve is not to your liking, follow this guide, which provides step-by-step instructions for reducing the circumference of the upper arm or bicep area of a sleeve. Basic sewing skills are required, but by following these instructions, you'll be one step closer to achieving that perfect-fitting shirt!
Was du brauchst
Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
Draw another line from the marking, extending down to align with the side of the body of the shirt.
Use straight pins to pin the sleeve across the lines you drew.
Push the pin through the top and push it back through the bottom of the sleeve.
Place a pin every inch across the lines.
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
